If the epoxy you are speaking of is epoxy primer, you really should use it for your base. It won't do as well when sprayed over primer. I am sure one of our experts will correct me if I am wrong, but I believe it is epoxy primer on the bare metal, bondo and other primers can be sprayed over the epoxy but you need to seal the metal with the epoxy.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
