Be careful with that e-coat try to take it off with lacquer thinner if it doesn,t wash off its ok but if it washes you need to get it all off. The tiywon stuff is bad news. I would put new skins on the doors it's way better looking in the end and easy to do. Epoxy first not cheap nightmare paint. Then filler,2-k high build primer, block it out use guide coat. If its high you hit metal if it's low it shows up guide coat.
