Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Body Work
Thread: Body Work
Old 02-20-2012, 07:29 AM
deadbodyman's Avatar
deadbodyman deadbodyman is online now
Wiki Edits: 11
Originally Posted by Formulajim
Be careful with that e-coat try to take it off with lacquer thinner if it doesn,t wash off its ok but if it washes you need to get it all off. The tiywon stuff is bad news. I would put new skins on the doors it's way better looking in the end and easy to do. Epoxy first not cheap nightmare paint. Then filler,2-k high build primer, block it out use guide coat. If its high you hit metal if it's low it shows up guide coat.
so true ..If your going to spend any time at all working an after market panel the first thing you do is remove all that junk primerwether it washes of or not just sand it off an start with an epoxy that you know is good ...the whole job is relying on that primer why would you take a chance on something your not sure of ??
