Body work - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2001, 05:18 PM
New Member
Post Body work
I would like for someone to help me to learn about hammre and dolly and metal shrinking books or advice.
Old 10-25-2001, 09:28 PM
Post
The best source for information is from GM performance on goodwrench engines . If you are reffering to a basic goodwrench 350 4v replacement or tbi engine there good stock engines and thats it . Your money is better spent at Summit or Paw on a crate performance engine . I was employed by GM for a time as a mechanic , I did warranty replacements and I saw the insides of may Goodwrench engines that were hopped up under the impression they were superior to what you find at the bone yard or as a reman replacement . They are just replacement engines , nothing special . The GM Performance replacement engines like the zz3,4, and 5 are very well designed street hot rod engines , very solid . Even though they are sold under the goodwrench logo all goodwrench engines arent created equil . If you are looking to buy one make sure you find out what it is exactly , a ZZ engine or a plain jane 350 replacement . Ask you Gm dealer for exact id identification . Never believe what someone tells you about one of these engines till you check the engine id codes , you will get ----ed very quick ,
Old 10-25-2001, 09:31 PM
Post
Im not sure what happened here , I replied to a question about goodwrench engines and it went here , as far as metal srinking information , I saw a book from peterson publishing in Hot Rodder about the subject , it included lead work and custom panel making
Old 11-14-2001, 03:12 PM
carnutjoef's Avatar
Post
Originally posted by Turkey:
<STRONG>I would like for someone to help me to learn about hammre and dolly and metal shrinking books or advice.</STRONG>
Old 11-14-2001, 03:17 PM
carnutjoef's Avatar
Post
Try the eastwood catalog. I got a good video with the lead tinning kit and there is another good video called Basic Techniques for working with steel by Covell. Both are well done and very informative.Good luck
Low buck body work procedure Ricky Rocket Body - Exterior 5 06-02-2006 07:53 AM
Feeling body work tip. MARTINSR Body - Exterior 8 05-29-2006 11:39 AM
My first real attempt at body work. What do you think? Ghetto Jet Body - Exterior 9 06-23-2004 04:40 PM
Body Work trick66 Body - Exterior 5 03-01-2003 01:18 PM
Grand Prix Body Work manofsteel Hotrodders' Lounge 3 11-09-2002 10:25 AM
