Body work - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2005, 08:57 PM
sscamaro_510's Avatar
Body work
How much would a job like this cost me? What I want takin care of is the surface rust pictured,sanded and primed...and i also want my front and rear windows taken out and fix whatever is wrong and re-sealed cause it leaks right now. Also the front fenders need to be aligned....roughly how much would a job like this cost me? a prep job...
http://pg.photos.yahoo.com/ph/sscama...bum?.dir=/51d6
Old 06-15-2005, 09:09 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
someone from your area will have to answer that, because prices are all over the place depending on location, cost of living etc..
Matthew
Old 06-15-2005, 10:15 PM
Probably going to be pretty pricey due to the time involved. I am willing to bet from the pics there are going to be rust holes when the areas are ground down, which means at the least welding in patches. Another thing is going to find a shop that will take it. A typical bodyshop doesn't take work like that unless they are slow, because it ties up the shop, and they make better money on collision repair. California labor rates are all over the place, from $80/hr in sanfrancisco to $38/hr in other areas. It might be worth taking it to another area if you find a shop to do it. If not you might have to take it to a place that specializes in restoration whos labor rates are normally higher. Its hard to tell without seeing the vehicle and a few pictures, but I'll take a stab and say maybe around 3,000-5,000 depending where you go. Just a guess. The glass you might want to check with some windshield places. Most bodyshops farm out the glass removal, and may be less expensive just going straight to the glass shop. Hopefully it is not rusting under the glass at all.
My first real attempt at body work. What do you think? Ghetto Jet Body - Exterior 9 06-23-2004 04:40 PM
i hate body work badknuckles Body - Exterior 21 03-22-2004 08:52 AM
Body Work trick66 Body - Exterior 5 03-01-2003 01:18 PM
Grand Prix Body Work manofsteel Hotrodders' Lounge 3 11-09-2002 10:25 AM
Body work Turkey Body - Exterior 4 11-14-2001 03:17 PM
