-   -   body work primer type (http://www.hotrodders.com/forum/body-work-primer-type-186394.html)
Carlos9 10-21-2010 09:51 PM
I have a question about bosy and paint. I remember years ago I had some body work done at a shop on my 66 mustang. I only wanted the bisy work done as I was still working on other things and paint would be later. I wanted the car back primered which that's what I got. Before I could get the car painted by the person that did the body work, the guy lost the shop and moved out of state.
Long storey short, I wanted another shop to paint the car, but they insisted I have the body work done all over again because the first shop used the wrong primer. I think my first guy was spraying dupont, and the second used PPG. Does this sound right. It's been a while so I can't really remember.
Having body work don on new car and don't want to make the same mistake. What primer do I want. The car is originally white and I would like to leave it original color. Car is a 64 mercury comet conv. Red interior. Like other car, not ready to paint. Just body and primer for now.
V8&4spd 10-21-2010 09:58 PM
You want to start out with epoxy primer. Don't worry about the brand name.
Runnin'OnEmpty 10-22-2010 08:38 AM
Originally Posted by Carlos9
Long story short, I wanted another shop to paint the car, but they insisted I have the body work done all over again because the first shop used the wrong primer. I think my first guy was spraying dupont, and the second used PPG. Does this sound right........
I'd find another shop. There's no reason to re-do perfectly acceptable
body work. All that's needed is to block sand a guide coat to make sure
everything's straight, then prime and paint with whatever the new shop
want's to use.
302 Z28 10-22-2010 08:45 AM
If you or the shop is worried about the existing primer there is no reason to re-do everything. Block sand the whole car down and apply several wet coats of SPI epoxy primer. It will seal the existing primer and provide an excellent base to either build more primer on or painting over.
Vince
sunsetdart 10-22-2010 10:18 AM
If the first shop used epoxy primer, then applying another brand epoxy primer is of no consequence. But if the primer is not epoxy based, sometimes there can be a problem with different companies paints and primers mixing with other brand names.
I would do what 302 says...........but whatever brand topcoat you are going to use , I would use that brand name primer as well.
