bodywork - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2011, 03:11 PM
bodywork
Hi my name is Don and i am bldg. a 54 dodge panel truck, frame and running gear are complete (that was easy) . Now the body work , I am presently sanding and removing rust! can I spray an etching primer on before plastic filler or doe's filler go direct to metal?
don
Old 09-14-2011, 04:31 PM
skip99's Avatar
filler right on the metal.just make sure the rust is dead...or all gone, use picklex 20 if it's bad..you can sand the whole thing, use picklex on the bare metal and take your time doing bodywork..
Old 09-15-2011, 04:53 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Most etch primers are acid based and don't mix with body fillers.
You can use epoxy primer and filler on that, but filler on bare sanded
metal is fine.
Use epoxy on bare metal, it's compatible with everything and
does a much better job.
Old 09-15-2011, 06:21 AM
deadbodyman's Avatar
Wiki Edits: 11
Filler wont stick to etching primer.....
A lot of us feel epoxy first then filler is the best way to go for a lot of reasons
But I think everyone agrees epoxy is the way to go
Not all epoxies are the same do a little research before you buy one
Old 09-16-2011, 11:27 PM
put up or shut up
etch is only good for leaving something in primer to work on later and then sand it all off later. Nothing likes to stick to etch including fillers, primers, and paints. I think slick sand says it's ok but it's nothing I'd do. Works great for protecting metal from the elements and it's cheap.
Old 09-23-2011, 04:43 PM
thanks skip
I was going to use an ethcing primer , but not now found the last jug of picklex and will be sanding whole thing before priming . thanks
bodywork aaronr Body - Exterior 1 04-30-2008 04:25 PM
Help With Bodywork aphockey Body - Exterior 9 05-21-2007 08:25 AM
bodywork burnout loyter Body - Exterior 21 05-20-2006 10:33 AM
bodywork 73chargerpimper Body - Exterior 1 06-18-2005 10:09 AM
Bodywork with Fusor ??? KwikFord Body - Exterior 1 07-23-2004 11:30 PM
