bodywork confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2005, 09:41 AM
modas's Avatar
Dazed and Confused
Last journal entry: Trunk Part 21
bodywork confusion
Hello Gents and Gals
If I do a dip on the sheet metal for my '64 impala, do I do the bodywork first, THEN dip or vice versa?
Much thanks!
Old 06-29-2005, 09:57 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Dip it , then fill it
Old 06-29-2005, 01:21 PM
personally id say depends on your car! On my mustang, If i dipped it right from the start, i probably wouldn't have a car anymore. the acid would have eaten away enough rust that the thing would have come out in pieces!
if you car just has a few holes, by all means, dip it, spray the whole thing with epoxy, and work on, but in my case I think it will be replace as much metal as I can, Dip it if I can afford it to get rid of any inner panel rust and small pinholes, spray it with epoxy, then body work to make it perfect
Mike
Old 06-29-2005, 02:00 PM
BondoKing's Avatar
KING OF BONDO
Like I said DIP IT first, if it all falls off in the bath it is not worth restoring!!!!
Matthew
Old 06-29-2005, 02:59 PM
aka Duke of URL
Really. A bath or media blast will let you know exactly what you have to work with...
bodywork 73chargerpimper Body - Exterior 1 06-18-2005 10:09 AM
First Bodywork progress pictures. *DUW* Dubz Body - Exterior 4 11-30-2004 04:34 PM
temps for bodywork cornfieldcars Body - Exterior 2 10-19-2004 08:23 AM
when to say "when" with bodywork?? CHEV66JB General Rodding Tech 16 06-03-2004 07:40 AM
Some paint & Bodywork tips Kevin45 Body - Exterior 2 11-22-2003 07:45 AM
