bodywork sanding a 41 Buick - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2011, 10:16 AM
I am doing my bodywork and sanding using a flexible sanding board. This car is has a very large curved body . I am sanding the bodyputty on roof right now with 80 grit and the flexible board and guide coat but should I be using a Da sander for this work ?
Old 05-22-2011, 10:52 AM
I would use a DA just to knock down the excess body filler but then I would come back with your long board
Old 05-22-2011, 12:14 PM
mitmaks's Avatar
Last journal entry: Grille
You could use mud hog sander to quickly knock down excess bondo.
Old 05-22-2011, 12:21 PM
mitmaks's Avatar
I like K blocks since they flex very well and come in different sizes
http://cgi.ebay.com/ebaymotors/16-Lo...motiveQ5fTools
Old 05-22-2011, 06:07 PM
Sixguns's Avatar
you should do just what your doing. sure there are tools that will mkae the job go faster but there would be a risk involved for a novice, you could end up makeing a mess of it and have to start over, much less risk with your long board. I dont think your in a hurry anyway so why rush it.
minor ? - wet sanding vs color sanding cboy Body - Exterior 33 10-06-2012 06:35 AM
i see sanding strokes from bodywork they weren't there last week? krazeyone Body - Exterior 19 06-07-2010 02:36 AM
Wet Sanding Clear Coat: DA vs Hand Sanding? off2wildblue Body - Exterior 8 05-25-2009 07:05 AM
Help With Bodywork aphockey Body - Exterior 9 05-21-2007 08:25 AM
DA sanding vs hand sanding Kevin45 Body - Exterior 31 07-19-2005 01:37 PM
