bogus machine shops? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 09:52 PM
i reacently had a 350 4 bolt main bored .040 balanced blueprinted and a step 1 RV cam. the heads were done at the same shop. It wont even power stall. Ive tried severaal carbs ignitions and was thinking about a new rear end might help it has a 2.56 rear end. let me know what you think is maby the problem.
Thanks
Old 10-20-2008, 09:59 PM
techinspector1's Avatar
Wiki Edits: 326
Post the following and we'll try to figure it out for you, although replacing the gears will be a big step forward.
Cylinder head casting no. and chamber cc's
Piston mfg, part no. and crown configuration
Piston deck height
Head gasket thickness
Cam mfg, part no.
Intake mfg, part no. or casting no.
Carb mfg, cfm, vacuum or double pumper
Headers or manifolds. Primary tube size if headers.
Old 10-20-2008, 10:11 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Thanks
A rear end change into the 3's would get the torque into the right rpm range, that's why your flat!
Old 10-20-2008, 10:46 PM
4 Jaw Chuck's Avatar
What is a "step 1" Rv cam? Most Rv cams I have seen are not much better than a stock cam.
2.56 gears! There is your problem!
Old 10-20-2008, 11:12 PM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
im not familiar with the term power stall, but i take it to mean a burnout.
in addition to the info that has been asked for, some other info to include is if you have a posi read end, what tires you have and their height & width, & the stall speed of the
converter.
i have a 2.42 gear with an open diff in my car and my problem is a lack of traction.
a nice burnout looks cool, but at the track if your spinning the tires, your wasting time.
Old 10-21-2008, 07:26 AM
Banned
TO break the tires loose with a stock setup (which is basically what you have) the easiest and cheapest way is to increase the stall, however increasing the gearing will have a far greater impact on your acceleration.
Step up to some 3.42's and a 2,000 stall- even the mildest 350 will give you a good amount of pull with that combo... unless its in a 1 ton truck pulling a loaded horse trailer or something.
Old 10-21-2008, 11:57 AM
Last journal entry: PICTURE TEST
engine
Did the machine shop build you what you paid for??? I mean did you ask (or only wanted to spend X amount of money) for a stock cam, heads,compression etc???
If so then the title of your thread needs changed...
What type of car is this in??
Does it still have the stock exhaust manifolds and single exhaust??? How about intake and carb???
If there is a brake problem and only the back brakes on the car are working correct and your trying to power brake it, a 350 hp engine will probably not spin the tries with 2ish rear gear...
Keith
Old 10-21-2008, 12:04 PM
Banned
I think a 350 horse engine can easily spin the tires with that gear- I don't think he has an honest 350 horse engine though. It looks like he has a stock rebuild with an RV cam- which puts him more at 250 horse. That with a 2.42 rear gear probably won't spin the tires much.
There's nothing wrong with a stock rebuild- it still gets you down the road, just don't expect it to be more than a stock engine.
Old 10-21-2008, 01:12 PM
engine
I don't think it's 350 hp either...
More like 200/250hp. It was just a statement that if only the back brakes are working, you have the tires locked that your trying to spin.
Keith
Old 10-21-2008, 07:15 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I didn't read anywhere where he said 350hp. It's a 350ci 4 bolt main.
Old 10-22-2008, 07:12 AM
Banned
k-star was talking about 350hp. And most people assume a built chevy 350 is going to ahve ATLEAST 350 hp- but in this case its only slightly better than a stock 210.
Old 10-23-2008, 07:46 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
Even a stock motor can peel out if its in a good state of tune.
Find out your compression ratio and camshaft specs, then adjust your timing curve to match it. If your cam is much over stock with low compression then you need a lot of timing advance, maybe 17 at idle and 36-40 total.
Are there any good machine shops dragginby Engine 0 04-02-2008 12:48 PM
Machine shops in Las Vegas NWayne Engine 2 05-13-2007 09:53 AM
Good Machine Shop(s) in L.A.? swerve Engine 7 12-23-2004 11:56 AM
Are machine shops dying off? Jmark Engine 32 09-12-2003 06:36 PM
Any good machine shops in San Diego? malibu65ss Hotrodders' Lounge 0 09-17-2002 05:44 PM
