Bolt broke - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2007, 02:35 PM
Mr.NutCase's Avatar
Bolt broke
I overtighted a bolt on a 1993 Altima, broke the "air bleed crew/cap,it is by the themostat hausing, the socket size is a 10mm, How hard would it be to remove the bolt
Old 01-01-2007, 02:54 PM
It might be too small to use an easy out. I might just try drilling it out then puttin a bigger tap through it
Old 01-01-2007, 06:55 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Sometimes just using a left handed drill bit will bring one out.
Old 01-03-2007, 06:05 AM
How tight is the remaining bolt in the manifold? I've used electric engravers to back out broken bolts/studs. The vibration loosens things up to a point. Just do it in a counter clockwise rotation. This may work. Some times a using a center punch tapping it works also. One last desperate thing to try is welding a bolt or a nut on to what's remaining of the old bolt. That way you have something to grab.
Old 01-11-2007, 08:17 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
make a screw with a dremel tool
Old 01-19-2007, 12:54 PM
4cyl Pentastar Fanatic
I have used easy out's from Craftsman for bolts as small as M6. You should be able to use an easy out no problem, the one you broke is probably M8. The left handed drill bit mentioned previously works a good deal of the time as well! Just make sure your drill is in reverse.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 06:27 AM
5" waterpump bolt (Ford 289) head broke off and frozen in waterpump ccarccrazy Engine 6 07-14-2006 02:31 PM
Broken 4 Bolt Main Cap Teejay68 Engine 8 05-30-2005 12:23 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
