Bolt holding TV cable in the Trans. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2007, 08:24 PM
Hey Guys, I ordered a TV cable from GM and when I put the trans. end in place, I could find not find the bolt. It may not have been in the pack, or I dropped it, not knowing. The transmission is a 700r4, 1990, using a carb.
Can someone tell me the size, lenght, and thread pitch, so I can finish the driver train on this truck?
Thanks in advance.
Old 12-28-2007, 08:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks in advance.
6mm x 1.0 thread pitch.. I forget the length.
Old 12-28-2007, 10:04 PM
Thanks, about 1/2 or 3/4" should hold OK. I will check how deep the hole is in the morning.
AOD TV Cable Linkage? InjunSHZ Transmission - Rearend 3 08-26-2007 06:59 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Need Help, adjusting a lokar tv cable maninacoupe Transmission - Rearend 2 10-01-2006 06:25 PM
TV Cable Brackets HawkZ28 Transmission - Rearend 1 06-24-2006 09:53 AM
