Bolt length, t-350 to the engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2007, 07:51 PM
tfeverfred's Avatar
Nuevo Retro T Buckets!
Last journal entry: Last entry
Does anyone know what size the bolts are that attach the 350 turbo trans to a 350SBC?
Old 08-07-2007, 07:59 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Should be 3/8-16.
Old 08-07-2007, 08:01 PM
tfeverfred's Avatar
Originally Posted by Blazin72
Should be 3/8-16.
About 2" long?
Old 08-07-2007, 09:26 PM
AllSteel34's Avatar
1.5 inches, if memory serves me correctly.
Chris
Old 08-08-2007, 08:09 AM
XNTRCI-T's Avatar
AKA Lee in KC
I used studs. You can be sure you're torquing against the bellhousing and not the bottom of the hole in the block.
Old 08-08-2007, 09:06 AM
biggeazy-e's Avatar
Lol, not a bad idea, would also help mating the engine/trans...
Old 08-08-2007, 05:57 PM
tfeverfred's Avatar
Thanks for the info, guys.
Old 08-08-2007, 11:13 PM
Jmark's Avatar
1 1/2" bolts OR 2" studs if you have room against the firewall.
Old 08-08-2007, 11:49 PM
jakeshoe's Avatar
GM used 1 1/4" bolts. 1.5" are too long except maybe on the dipstick.
Chevy engine ID, can anyone help id my 350 engine? Ron Garcia Hotrodding Basics 23 01-31-2008 03:51 AM
where to look for sbc 350 4 bolt mains? malibu68 Engine 3 12-18-2006 07:01 AM
350 w/ 2 bolt main and supercharger? McDeuce Engine 13 09-01-2006 10:10 AM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
Target 350 engine palcu Engine 1 08-18-2003 01:40 PM
