Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bolt Positions
Thread: Bolt Positions
Old 08-13-2012, 12:24 PM
andrewakessler's Avatar
andrewakessler andrewakessler is offline
Bolt Positions
Hello,
I'm working on a g body frame, and I'm trying to figure out how "positions" are determined on the frame so I can buy some new bolts.
Does anyone have a diagram showing this info? I can't seem to find it anywhere.
Thanks,
-A
Here are the G-BODY body ,mount bolt specs:
Position 1 uses GM P/N 10049638 (sold ea., 2 needed). Bolt is 12 X 1.75 X 95mm long.
95mm is not common so you have to use 100mm.
Position 3 uses GM P/N 14085301 (sold by pkgs. of 5, 2 needed). Bolt is 10 X 1.5 X 55mm long. Also need two nuts.
Position 2, 4, 6, 7 uses GM P/N 3524497 (sold by pkgs. of 5, 8 needed). Bolts are 10 X 1.5 X 80mm long.
