Bolt Positions
Hello,
I'm working on a g body frame, and I'm trying to figure out how "positions" are determined on the frame so I can buy some new bolts. Does anyone have a diagram showing this info? I can't seem to find it anywhere. Thanks, -A Here are the G-BODY body ,mount bolt specs: Position 1 uses GM P/N 10049638 (sold ea., 2 needed). Bolt is 12 X 1.75 X 95mm long. 95mm is not common so you have to use 100mm. Position 3 uses GM P/N 14085301 (sold by pkgs. of 5, 2 needed). Bolt is 10 X 1.5 X 55mm long. Also need two nuts. Position 2, 4, 6, 7 uses GM P/N 3524497 (sold by pkgs. of 5, 8 needed). Bolts are 10 X 1.5 X 80mm long. |
Do you have the original bolts? Just buy new ones that are the same. What am I missing here?
Brian |
| All times are GMT -6. The time now is 07:37 PM. |
