Bolt Positions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 11:24 AM
andrewakessler's Avatar
Bolt Positions
Hello,
I'm working on a g body frame, and I'm trying to figure out how "positions" are determined on the frame so I can buy some new bolts.
Does anyone have a diagram showing this info? I can't seem to find it anywhere.
Thanks,
-A
Here are the G-BODY body ,mount bolt specs:
Position 1 uses GM P/N 10049638 (sold ea., 2 needed). Bolt is 12 X 1.75 X 95mm long.
95mm is not common so you have to use 100mm.
Position 3 uses GM P/N 14085301 (sold by pkgs. of 5, 2 needed). Bolt is 10 X 1.5 X 55mm long. Also need two nuts.
Position 2, 4, 6, 7 uses GM P/N 3524497 (sold by pkgs. of 5, 8 needed). Bolts are 10 X 1.5 X 80mm long.
Old 08-13-2012, 12:42 PM
Do you have the original bolts? Just buy new ones that are the same. What am I missing here?
Better core block for sbc 383, 4-bolt flat or 2-bolt roller? Cousin_Joe Engine 24 02-08-2008 08:50 AM
connecting rod positions? deathbypontiac Engine 7 05-21-2007 04:38 PM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
Ford C4 Transmission shift positions RAW Transmission - Rearend 6 11-29-2006 10:18 AM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
