Bolt Removal HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2004, 11:06 PM
badriand's Avatar
I am trying to restore a 41 chevy truck, so I start looking at the bolts, srews and notice that all of the interior around the window, door panels, door hinges everything has this screw that is kind of like a square but with half moons on each end. I cannot find anything to fit for removal. Checked at local auto stores and chevy dealership and I get looked at like I am retarted. Does any one know where to get something to remove these screws. So far I have just been using a drill bit and drilling them out but it is a lot of work. Thanks in advance...
Old 04-07-2004, 12:02 AM
Badriand,
This is an "OLD" chevy style screw head. It was called the "Chevy hour-glass" I do not think you can buy it any more, but you might see one at a swap meet.
I find grinding an old scredriver to the shape you need works just fine. Grind it slow so you do not take the temper out of the blade.
On the bigger screw heads with this style head like on the 57 truck beds I weld a nut to the screw and then use a wrench. I then replace them with stove bolts.
Good Luck
Scholman
Old 04-07-2004, 12:12 AM
New Member
Cool - I'm rebuilding a '41 also! The screws are called "Clutch Head" screws. Several sizes are used throughout the truck. You can buy 1/4" drive bits at:
http://www.lara.com/cgi-bin/store/co...specialty_bits
Get all the sizes - they're cheap!
Here's a pic of my truck.
-Max
Old 04-07-2004, 08:38 AM
badriand's Avatar
Im jealous , I am just getting started and mine has that 60 year old rustic look going on right now. Thanks for the help...
Old 04-08-2004, 02:23 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
yeah the clutch head drivers are also available through any classic truck shop./
Old 04-09-2004, 10:20 AM
johnnymopar's Avatar
Love your nails! You must be a Libra
i remember my buddy telling me about clutch-head screws on his truck and i think he said to use a torx bit and grind off two of the points to fit the head.
can't remember for sure, though.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 04-09-2004, 01:40 PM
The clutch head screws are very common on 55, 56, & 57 Chevy cars - suplliers for these cars like Danchuk carry the bits and screwdrivers in a few different sizes
