Rule of thumb for a Grade 8x20UNC is 15 000 psi of tensile strenght. So that means a dry torque of around 80 Ft./Lbs, olied would be around 60 Ft./Lbs
Good luck Sorry i made a mistake, i meant 150 000 P.S.I of tensile strenght. Hey what do you know, my first mistake! lmao, just kidding. |
I use a head stud on my motor for the balancer, just a thought it's Grade 8x20UNC also.
Luv the smell of NITRO in the morning. |
How can the bolt break? If you got the crank bolt tight and you go too far the crank moves?
This is not the first time I have heard of one breaking and wont be the last.
I watched a guy break an 1 1/4" grade 8 bolt with a wrench. He was pretty proud of himself, showing his strength and all. He just wouldn't admit that sometimes you get a bad bolt in the bunch. I routinely have to torque the same type bolt to 1,200 ft.lbs. Unless you were going crazy with the breaker bar, it was most likely a bad bolt. It happens.
Stainless steel is bad for 'grabbing' and 'jamming' if that happened to be the material of the bolt. Oiling them up or even Loctite helps a great deal. I swore so many times bolting a SS bolt to an Aluminium bracket.....and the corrosion after just a short while, lets not even go there
Remember it's always best to turn your motor over with a crank socket and not the crank bolt. I knew this, but didn't follow the procedure, but now after knowing this for 20 years I will finally put it into practice. |
Hello.
I build a lot of small block chevys and some as high as 14 to 1 compression ratio. I use a lot of ARP bolts, and have found the to be as good as it gets. If you call their 800 number and tell them about that bolt just breaking I bet they will want it back and replace it if not more. They have great products and are great people. I buy the balancer bolts for most of the milder motors in bulk ( grade 8) at fastenall as well. They work fine, the washer i have to buy from GM. Im sure ARP will be shocked to see this failure. Thanks Jeff |
I have a complete ARP bolt set on my engine and had three timing chain cover bolts snap off right under the head. They hadn't even begun to bottom out and there was no force on the bolt. The heads just fell off.
id like to see your torque wrench!!
Just to comment on the possibility of a bad bolt, My brother is a machinist for a company that makes specialty hardware. They make everything from hardware store stuff to aerospace hardware. They are having all kinds of problems getting repeatable quality steels from the american steel mills. One batch will be dead on in all aspects. The next batch might meet the hardness spec but be extremely brittle. The problem has gotten so bad that they have had to start getting Japanese steel in order to meet the specs on their high end hardware.
