bolt swaping, pontiac 350 to a 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2010, 11:48 AM
Ive got everything together to build my 455, being that 90% of the bolts can be interchanged would i be hurting myself to reuse them on my new motor?
the 350 only has 100k original miles and is VERY clean under the hood.
I know bolt kits are between60-100$ for a full engine kit, but they dont come with head and main cap bolts which are 100$ alone.
Is it safe to reuse the head bolts and the Main cap bolts from the 455?
Old 09-07-2010, 03:38 PM
Last journal entry: Unpacking
id reuse the smaller bolts that aren't under alot of stress. ie. oil pan/intake. i wouldn't recommend using the head bolts over. snapping a weak head bolt while torquing it in the block will cause you more of a pain then just springing for new blots
Old 09-08-2010, 02:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you want MY opinion, I'd reuse the 350 bolts on a 455 (all except rod bolts and nuts, obviously) or vice versa w/o hesitation. Main, head, intake, etc. I would (and HAVE) reused all of them.
Pontiac Torque Specs
Damper Bolt 160 ft/lb
Camshaft Sprocket-to-Camshaft Bolt
40 ft. lbs.
Camshaft Thrust Plate Bolts
20 ft. lbs.
Cylinder Head Bolts
1977 301 cu. in. Engine
85 ft. lbs.
1977 350 cu. in. Engine
100 ft. lbs.
Don't reuse these at the lower 400 cid torque spec, if the 350 you are using is a '77.
All Others
95 ft. lbs.
Exhaust Manifold Bolts
1970-76
30 ft. lbs.
1977 and Later
40 ft. lbs.
Flywheel/Driveplate Bolts
95 ft. lbs.
Intake Manifold Bolts
1970-76
40 ft. lbs.
1977 and Later
35 ft. lbs.
Main Bearing Cap Bolts
Caps #1 Through #4
301 cu. in. Engine
7/16" Bolts
70 ft. lbs.
1/2" Bolts
100 ft. lbs.
All Other Engines
100 ft. lbs.
Rear Cap ( #5 )
301 cu. in. Engine
100 ft. lbs.
All Others
120 ft. lbs.
Oil Pan Bolts
12 ft. lbs.
Rocker Arm Cover Bolts
6 ft. lbs.
Rocker Arm Nuts- non adjustable bottleneck studs only
20 ft. lbs.
Rod Bearing Nuts
1970-76
43 ft. lbs.
301 cu. in Only
30 ft. lbs.
All Others
40 ft. lbs.
Thermostat Housing-to-Intake Manifold Bolts/Stud Bolts
30 ft. lbs.
Timing Chain Cover Bolts/Nuts
30 ft. lbs.
Timing Chain Cover-to-Intake Manifold Bolt
15 ft. lbs.
Vibration Damper-to-Crankshaft Bolt
160 ft. lbs.
Choose Pontiac 400 or 455? & Turbo Questions TheMonkey Engine 33 08-12-2009 12:01 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 04:45 PM
pontiac YA 455, coded for 1970 GTO, loading up Gladis Engine 3 04-07-2007 12:52 PM
Olds 455 vs. Pontiac 428?? 428BIRD Engine 4 04-06-2007 05:06 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 10:11 PM
