bolt will not thread into hole ran a tap through several times - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-04-2009, 05:20 AM
Last journal entry: Bringing home the 401 Nailhead
Originally Posted by hotbrat
I was thinking about this today. If I hammer on a tapered bolt would that work to chamfer up the first threads
No you will damage the threads. You could chamfer the threads with a small round file if you don't have a dremel or a stone to fit the drill. Just be carefull to clean up any filings.
  #17 (permalink)
Old 12-04-2009, 05:42 AM
deadbodyman's Avatar
Wiki Edits: 11
Take the head off and the gaskit then thread the bolts in the holes...If they all work it must be the gaskit or the head's not lining up ...
  #18 (permalink)
Old 12-04-2009, 08:21 AM
m12 is pretty large. the dremel heads are tiny.
How about using a large drill bit to drill out the first threads
  #19 (permalink)
Old 12-04-2009, 10:37 AM
Nix the drill. It could grab and suck itself in damaging too many threads. Use the dremel or a round file and just go around the very top of the hole.
  #20 (permalink)
Old 12-04-2009, 11:01 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
That was my experience recently with a SBC. Removed head, cleaned up threads in engine block, and used new head bolts. One head bolt would not start properly with head sitting on the block and dowl pins engaged. Remove head and bolt would start and thread in perfectly into the block. Put head and gasket back on and no luck. I took the head over to the mill/drill and enlarged the problem hole by a 1/16" and problem solved.
  #21 (permalink)
Old 12-04-2009, 11:33 AM
You betcha! That thing would almost certainly grab and if it is a high torque drill it could damage the threads really deep, even a low torque drill would probably damage the first 3 or 4 threads.
  #22 (permalink)
Old 12-04-2009, 06:52 PM
4 Jaw Chuck's Avatar
Measure the bolt, pitch in only one aspect of bolt sizing...sounds like you have a larger M13 or M14 bolt there.
— Han Solo
  #23 (permalink)
Old 12-05-2009, 07:35 AM
Wiki Edits: 11
Aftermarket or chineese heads? you could try studs....I'm assuming you had them milled true....ME,I'd drill the hole(in the head) out bigger, cast is easy to drill out...It might even be a warped deck, EZ to check with a straight edge and a feeler gauge...Try switching the ones that work to the holes that dont ,that'll tell you if its the bolts or the holes.you could even try holding the head off the deck to clear the pins with a wooden dowel,get all the bolts started and remove the wooden dowel,but if the bolts are getting bound up that'll change the torque readings....I wouldnt mess with the block at all..
  #24 (permalink)
Old 12-05-2009, 08:19 AM
welder4956's Avatar
If you have run bolt thread taps through the hole, then the first threads have the same diameter or larger than the threads in the rest of the hole. I did not see where you mentioned whether you were trying to thread the bolts in with the cylinder heads on of off. If they won't go in with the heads off, then the bolts have to be larger diameter than the tap.
If these are new bolts, then you might try threading the old bolts into the block to verify they thread correctly. If you have a local bolt supplier, take both the new and old bolts to them to check thread diameter. They may be mismachined or oversize bolts.
  #25 (permalink)
Old 12-05-2009, 08:41 AM
bentwings's Avatar
bentwings
Uhh are you turning the bolt the right direction.?? "Righty tighty, lefty loosey" for right hand threads.
  #26 (permalink)
Old 12-05-2009, 06:37 PM
the head is off; i do not have the head or head gasket on
Yes I am going right to tighten them. im not an idiot!
the thread pitch is slightly larger than the old pitch if not the same.
The dremel idea sounds like a good idea if I can buy the parts
  #27 (permalink)
Old 12-05-2009, 07:01 PM
gas_guzzler's Avatar
Sorry if I missed seeing it some where, but if you're having trouble with one particular hole have you tried fitting one of your other old bolts that screw nicely into another hole in it?
Sounds really unusual with all the things you've tried.
I don't have a dremil tool so I'd use a proper (and sharp) countersink tool.
Just some ideas, dont mean to offend any one...
Edit: Also did you try a M12x1.75 nut on your tap as mentioned earlier?
  #28 (permalink)
Old 12-05-2009, 11:47 PM
You need to verify the thread pitch and diameter are the same, these are the essentials of any threaded interface. If you don't have a vernier/micrometer you can use a strip of paper wrapped around the bolt to determine circumference. To verify pitch take a piece of paper and rub it onto the threads and compare them.
Metric fasteners often use identical pitches for different diameter fasteners, I think that is where your problem is.
— Han Solo
  #29 (permalink)
Old 12-07-2009, 07:13 PM
i have a micrometer; they are the same yes!
Remember I said I ran a Die and nut over the bolt; that verifies the size of the bolt to be what I think it is
  #30 (permalink)
Old 12-09-2009, 12:38 AM
Are there any other markings on the tap besides the M12 x 1.75? Maybe something like H11 or D6 or some other combination of letters and numbers. Someone could've sold you a special undersize tap instead of a standard one and they can usually be identified by some additional makrings on the tap shank.
Tap Hole Sizes? 345 desoto Engine 3 04-12-2009 01:47 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
