bolt will not thread into hole ran a tap through several times
I have a couple head bolt holes that will not accept bolts
I can tap them easily with a taper tap or bottom tap with ease when I tried to run a head bolt on it would not thread i went 2 the store and got another new bolt and tried that today. It would not thread on. Then I tried a chaser bolt but that would not thread on either Does anyone have any ideas on how to get a bolt to thread on if it does not thread? It seemed to thread on the first try but it jumped off the threads |
what are you working on? Standard or metric? A little more info might help.
metric
size m12 x 1.75 thread |
Are the taps a good brand or maybe a cheap set from Harbor Freight?
If its a good brand tap and the bolt has the correct thread I see noway you should be having a problem. Quote:
First off - take the bolt and lay it along the tap. Do the threads match? If not there is the answer.
Second - you said it tried for a few turns but then popped out. This sounds like it tried to cross thread. Take a sacrificial bolt and taper the end on a grinder. Clean up the threads with a thread file and then try it. If that works you may have to chamfer the very top threads of the hole or bolt. Third - you say a head bolt. Are you trying to screw the bolt into the bare block? If you are trying with the head and gasket on maybe the holes are not lining up. |
You might try using a nut to get an line on the bolt size and verify that tap is correct... could it be the bolt is to short ...?
A much better and easier way to clean up threads from tapering a bolt, of if you have to shorten a bolt by sawing or grinding, is to thread a nut (all the way to the shank) onto the bolt first. Then after grinding the threads, either to taper the bolt or to just taper the first thread or two after sawing it off, remove the nut and it will clean up the threads as it comes off. Doing this is much easier than using a thread file and leaves the threads perfectly aligned and clean so it will start straight every time.
lined up 3 different bolts with the TAP, they line up perfectly the tap runs through the threads with ease I took a bolt and grinded 3 sides making a thread chaser, it does not thread on period. The other 2 bolts do not thread on. All 3 bolts are the same size and thread pitch. both the bottoming tap and plug tape or taper tap thread on perfectly I am going to try again with a tapered bolt according to the last response. I do not think its going to work. I almost think the first thread is not large enough to allow the bolt to thread in |
| Recent Garage - Tools posts with photos |
| Tap Hole Sizes? | 345 desoto | Engine | 3 | 04-12-2009 01:47 PM |
| "Bowed" deck lid | cruzinTLT | Body - Exterior | 3 | 03-04-2005 09:24 PM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
