bolting a BBC to th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 06:50 AM
Although not typically seen, can a 427 or 454 be bolted to a 350 tranny? I'm not asking about if the tranny can take it, will it connect? shaft spline, bolt pattern etc
Old 07-11-2010, 07:20 AM
31 five window
Last journal entry: grill and rear end
Yes,A TH350 will bolt to a BB Chevy. If you had a TH400 behind it before the drive shaft yoke will have to be changed. The 350 output shaft is smaller than the 400.
Old 07-11-2010, 07:33 AM
Dont got nothing behind nothing yet bro. Did a SBC stroker this time but thinking of a true BB for the 69 impala next time but hates giving away HP to the 400 tranny. Thats why I'm thinking of just building another good t350
Old 07-11-2010, 10:55 AM
sqzbox's Avatar
My pipes are my music
That's the sweet thing about chevy, the tranny's interchange. I think you'll like the 350 as it seems they respond the smallest trans. shift improver kit's a little better that the th400 at least 1st to 2nd shift because of the lower 1st gear ratio. I put a B&M shift improver kit in both and the th350 would bark the tires where the th400 wouldn't.
Old 07-11-2010, 11:46 AM
I already use one behind the stroker just wonder if it'll bolt to the BB and I got my answer. Now I gotta figure if I want the hassle of building a BB or just shut up with what I have. I mean theres only so much rubber you can leave at a stop light
T-350 or T-400 in C10 ekacpuc Transmission - Rearend 2 05-17-2010 03:17 PM
T-350 Rebuild Tech jakeshoe Transmission - Rearend 10 10-05-2008 04:58 PM
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 04:43 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 11:16 AM
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 06:47 PM
