Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bolting a glass body to frame? rubber spacers
Old 05-04-2008, 02:00 AM
bentwings's Avatar
bentwings bentwings is offline
bentwings
I spent a lot of time designing mounts with rubber spacers and made them so the bolts do not contact the frame or body directly just like today's cars and trucks. The biggest problem is trying to make the body strong enough at the hard points. If you look at todays cars and trucks you can see the effort that has been done in this area. Keep in mind that they also have access to any amount of stress analysis testing needed. After doing some stress analysis I was all set to fabricate them and then asked myself why do this when the car is only going to be driven occassionally and never off road. Henry and the others already did this a long time ago and it worked for them. So I scrapped the idea....rather dumped it in the recycle bin. haha The web works great. I made a couple hole cutters to make installing it easier. Actually you can just drill right thru it. I did use nyloc nuts to allow even tightening and assurance that the fastener assembly will stay tight.
