We're winning the case!
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 07-10-2007, 08:29 PM
KGRIFF KGRIFF is offline
Bolting slicks
We are running a mild bracket car with 29 by 10 slicks mounted to 10 inch rims the tires have tubes in them. I marked the and one is showing monement of about 1 inch after 4 runs. They guys at the track are giving me two different opinions on how to correct the problem 1 is to use 3/4 inch long self tapping sheet metal screws the other is to remove the tubes and run without screws. Which way would be better?
Old 07-10-2007, 11:11 PM
WDCreech's Avatar
WDCreech WDCreech is offline
looking for that 7sec 1/4
Don't use sheet metal screws. Use rim screws, sold by Jegs?Summit, ets, Usually Moroso. There are rules by NHRA/IHRA about the grade of screws that can be used.
Old 07-13-2007, 12:03 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
techinspector1's barnstar
Wiki editor
Last wiki edit: Threading tips
Wiki Edits: 210
While there are certain areas of the car where bolt grades are spelled out in the rules, rim screws are not one of them. Matter of fact, they are not mentioned at all in the 2007 NHRA Rulebook.
I do agree with you, however, that dedicated Grade 8 screws such as those offered by Moroso are a far better choice for the task than cheap hardware screws.
Old 07-21-2007, 09:09 PM
larryblack's Avatar
larryblack larryblack is offline
Certified Lead Foot
Location: Red Stick, Cajun Land, The Dome, TX and I-10 in between.
drill the holes in the rim and use the screw to tap into the bead of the rim.
Make sure and champher the holes in the rim to prevent cutting the bead.
using tubes with slicks was once mandatory.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Bolting slicks"
Street Slicks HotRodS10 Hotrodders' Lounge 10 07-30-2007 09:11 PM
Need info on SLICKS "70" Cougar Hotrodders' Lounge 3 06-08-2006 01:14 PM
Slicks!!!! cojohnso General Rodding Tech 11 07-10-2005 12:01 AM
Storing slicks? KNanthrup General Rodding Tech 4 04-14-2005 07:48 PM
T-56 and slicks? 352FORD Transmission - Rearend 3 08-10-2003 01:03 PM
