bolts for headliner trim? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2010, 11:07 AM
Jason7504's Avatar
does anybody know what size screws/bolts are used to mount the front and back headliner trim/moldings in late 2nd gen's?
Old 03-07-2010, 12:01 PM
Wiki Edits: 31
2nd gen what?
Old 03-07-2010, 02:22 PM
Jason7504's Avatar
Originally Posted by matt167
2nd gen what?
oh sorry probably should of mentioned it was a 2nd gen camaro, 1981 to be exact
Old 03-08-2010, 10:49 AM
I'd have to look at what I used on my '78 T/A to be sure, but I'm thinking they were #10 oval-head screws, 'bout an 1" long - I had just picked up some of the pre-bagged screws from the local parts store that looked like they'd work (and they did!).
Old 03-08-2010, 11:13 AM
Jason7504's Avatar
and they screw into the slits?
Old 03-08-2010, 12:31 PM
Yep - right into the slots, no problems with them being loose or pulling out. If you're looking for a certain type, then try the trim screws that don't have the built-in washer since the trim pieces are already dimpled for the screw heads. One thing you could do is find a regular screw that fits the slot just fine, and then match the diameters up with the screws available at the parts store (basically all I had done).
"Basics of Basics" Nuts and bolts MARTINSR Hotrodding Basics 10 06-28-2010 05:38 PM
Rant about aftermarket sheetmetal cyclopsblown34 Body - Exterior 27 01-28-2010 10:14 AM
corvette front clip rhinz1966 Body - Exterior 12 01-11-2010 04:57 PM
any help ya'l luvchevs Body - Exterior 6 01-06-2010 09:35 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
