bonding fiberglass to metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2003, 09:08 AM
stanjr41's Avatar
Post bonding fiberglass to metal
I have a 1941 chev. 4-door sedan that has been chopped,dropped and every body panel smoothed or modified.I replaced the rear fenders with a set of glass 2"wider rear fenders. I want to mold the fenders into the body for a smoother look.Do I use some of the new adhesives between the fender and the body,bolt it back together and then fill the seam with some type of filler?If there's a possibility of cracking later on I don't want to try it.
Old 06-02-2003, 10:23 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
That's not a good idea for a part that big on a car. You can get away with bonding a hood scoop which is small and lightly loaded, but bonded fenders will always fail. Too big, too much vibration and exposure to the elements.
Old 06-02-2003, 08:47 PM
Post
Willys is right. Fiberglass and metal make a poor bond. Eventually you will see a ring around the joint. 3M makes a panel adhesive that works not bad but is expensive. You need a special applicater gun as well.Have used it with some success but you'll take a chance with it.
Old 06-03-2003, 12:46 PM
deuce_454's Avatar
Post
well if you have a good quality fibreglass part, it is possible to bond it on to steel, but not if you use polyester, you need to use epoxy, good e-glass rowing or bi-directional glass.BUT the steel has to be 110% clean, i used a 60 grit sanding wheel on an angle grinder, and then cleaned with first spray on clutch and brake cleaner, and then a silicone remover on a lint free cloth. that way the fender extension is glassed onto a large area of clean steel, useing a quality epoxy (it wont fail before the steel does- trust me)
but you HAVE to buy the epoxy, and it has to be one that is specified to bond to steel. i cant stress this point enough, polyester resin just doesnt wet the steel properly, i Contacted the local West-epoxy dealer. I am not sure where you would find one in your area, biut try a web search.
Old 06-03-2003, 01:39 PM
Wiki Edits: 21
Post
Here are the two I use
http://www.fibreglast.com/products.php?session=06da96d0d98588529435dede391ca 298&area=11
