Try a test piece first and see how it does. You may have to increase the catalyst ratio to account for the colder temperatures.
In SouthEast Texas in the summer all I have to do is take the cap off the catalyst tube and the filler starts to kick. Vince |
you might have it peel off later on
warm the metal with a torpedo heater then apply it. it will cure if you keep it warm.
i did some bodywork wed and it was colder than a you better not say here. |
What Shine said. If you cannot warm the barn up then warm the metal and then apply the bondo and keep a little heat on it untill it sets up enough that you can grate it.
As above, but just to make it extra clear - make sure you do it exactly as described and warm the metal first.
If you just throw it on cold metal, then apply heat after, you're asking for trouble. You're trying to heat it more 'from the back', if that makes sense.
Cold Bondo
For the small area your doing
if heating is a problem, use a hair dryer to preheat the metal and than cure the filler. If thats not good enough, J Clark uses an electric blanket. (I still laugh at that one!) |
bondo
Polyester resin doesn't cure well or at all below 64 degrees F. The metal and air should be above this temp for the bondo to cure. 64F is also going to be on the high side of the hardner ratio (1 1/2 to 3%).
overspray |
| SBC 18 degree head compared to 23 degree head powerwise? | sb72elcamino350 | Engine | 7 | 03-09-2010 02:01 PM |
| 30 degree intake seat angle on a SBC???? | baddbob | Engine | 5 | 06-20-2006 11:48 PM |
| Bondo vs Dynatron | ChrisMiddleron | Body - Exterior | 10 | 08-29-2003 04:07 AM |
| How long does it take thin amounts of bondo to crack? | stonedchihuahua | Body - Exterior | 14 | 07-12-2003 08:02 PM |
| bondo removal question | broncoman | Body - Exterior | 3 | 06-22-2003 01:16 AM |
