bondo and fiberglass - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2003, 06:55 AM
New Member
Post bondo and fiberglass
Need help! Is it ok to use bondo on top of fiberglass for car hoods? I used bondo to smoothen and shape a fiberglass hood, but realized that the hood will have a lot of expansion and contractions. Will bondo react with this? Any tip is greatful
Thanks
Old 05-06-2003, 07:11 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Marriage made in heaven! As long as the bondo isn't super thick (not a good idea anywhere), it will do super on fiberglass. Much more compatible than bondo and steel.
Old 05-06-2003, 10:49 AM
mitmaks's Avatar
Last journal entry: Grille
Post
id use fiberglass style bondo
Old 05-06-2003, 12:51 PM
Dragon J's Avatar
Last journal entry: Harley/Fire
Thumbs up
The scoop I did on my 'J <<< was fiberglassed on and the imperfections filled with minimal bondo. You'll be fine, just (as willys says) don't use it too thick or structurally.
Old 05-06-2003, 03:28 PM
bullheimer's Avatar
NEVER use credit cards!
Talking
so then it would be great for my glass spoiler, ala 72 camaro? i thought this plastic bondo was almost the same, just different.
