Bondo Headaches - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2006, 09:45 PM
2stroketurbo's Avatar
Rust makes me cuss
Last journal entry: Subaru Van
Bondo Headaches
I must be sensitive to the smell of bondo. I now get a screaming headache with one good whiff of an open can. I wear my new SAS supplied fresh air respriator when applying bondo, and when sanding it. So, other than a pain to drag around a hose, and listen to the air, it's much better for my noggin. Anyone else have this problem? Are ISO's present in bondo?
PS. I've been using evercoat RAGE lately.
Old 11-30-2006, 10:06 PM
No iso's in bondo. Not saying you aren't sensitive to some component in it such as polyester resin or peroxide or something. Everyone is affected by chemicals in different ways. I could practically swim in bondo without it bothering me. I've often come home covered head to toe in all metal dust at an old job I had. In fact me and another worker brought home some left over chicken from the boss, and both ate it. My coworker asked if I thought it tasted like bondo. I said no, why. He said he didn't notice anything either, but his girlfriend had some and said it did. Epoxy primer does bother me though and I will feel a little sick and get a headache if not wearing a respirator with new cartridges and have good ventilation.
If it is bothering you, I don't know what to suggest other then keep good ventilation, cover up, and wear your mask.
Old 11-30-2006, 10:23 PM
302 Z28's Avatar
It is possible to develope sensitivity to certain chemicals. Some people are more prone to it than others. When I was building radio control airplanes the CA adhesive gave me fits. I had been using it for yaers with no problem.
Vince
Old 11-30-2006, 11:42 PM
Rust makes me cuss
Quote :
"I've often come home covered head to toe in all metal dust at an old job I had. In fact me and another worker brought home some left over chicken from the boss, and both ate it. My coworker asked if I thought it tasted like bondo. I said no, why. He said he didn't notice anything either, but his girlfriend had some and said it did. "
Oh My! I will think of this every time I eat KFC.
Old 11-30-2006, 11:45 PM
mitmaks's Avatar
Last journal entry: Grille
doesnt affect me, although its good practice to apply it in well ventilated area. Do not stand over it and smell in vapors as its drying. Don't sniff dust either.
Old 11-30-2006, 11:56 PM
I used to work in a foundry pattern shop where we used bondo daily, after a few months I began to itch like crazy on my wrists, went to the doctors and they couldn't tell me what was wrong. Then I got a new job in a medical lab, plenty of chemicals but no bondo. The itch went away and I realized finally what the cause had been. The Bondo had never affected me before but when exposed daily I developed a reaction that comes back anytime I touch the mixture. Now I wear gloves everytime I am near the stuff.
Old 11-30-2006, 11:58 PM
powerrodsmike's Avatar
Wiki Edits: 161
Bondo has a bunch of styrene.
You can get sensitized to it over time.
It will give you a nasty headache.
http://www.epa.gov/ttn/atw/hlthef/styrene.html
Be glad you don't work with epoxy
http://www.fram.nl/workshop/controll...on/allergy.htm
Later, mikey
BE different....ACT normal.
Last edited by powerrodsmike; 12-01-2006 at 12:03 AM. Reason: put things in perspective with a link to something worse.
Quality of Bondo bartamos Body - Exterior 16 10-24-2006 05:22 PM
Removing old bondo arionrjw Body - Exterior 1 12-21-2005 09:48 PM
Which bondo should I use? Nightfire Body - Exterior 8 07-26-2004 06:38 PM
Bondo vs Dynatron ChrisMiddleron Body - Exterior 10 08-29-2003 05:07 AM
How long does it take thin amounts of bondo to crack? stonedchihuahua Body - Exterior 14 07-12-2003 09:02 PM
