Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bondo over fiberglass
Old 11-03-2005, 08:14 AM
BondoKing's Avatar
BondoKing BondoKing is offline
KING OF BONDO
Last journal entry: My little helper
Ducky if you are not going to get a welder... do this... get some short hair fiberglass... it has the fiber in it already... Fill your holes... sand down, cover with skim coat of glaze ( 2 part by the way, like Icing)..
Get access to the back of the panel and spray a rubber undercoating on it... Now you are sure you are water proof... I have used fiberglass before and never had any failures with it absorbing water, but there is always the first time for everything
Matthew
