Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bondo over fiberglass
Old 11-03-2005, 08:43 AM
red65mustang red65mustang is offline
"no welding required"
use 2 part body panel adhesive with a backing patch piece of metal on the inside of the hole (plastic filler and blend the patch if it's gotta be pretty)
use enough so it comes thru the hole a little, sand that down, plastic filler on top to blend your done.....
fiberglass cloth and resin is hydroscopic, gelcoat on fiberglas is the moisture barrier....
