Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bondo over fiberglass
Old 11-05-2005, 05:04 AM
adtkart adtkart is offline
If you have access to the back side, why would you drilll holes to pull it anyway? You should be able to work out the dent. If you haven't drilled the holes yet, don't. Either buy, or find someone that has a stud gun and use it. If you are going to repair it, repair it, not just cover it up.
