Bondo over fiberglass - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-05-2005, 07:07 AM
"hard to get to holes"
"like inside a door" (one of the worst areas for rust cause of wet and dirt and air circulation)...
take the door off, lay it flat, hang it up side down, whatever it takes to coat and treat the inside if you drilled holes or it will rust thru quickly from the inside
in other words....don't drill a door, pay a shop to stud pull it or hammer it out from the inside as Adcart wrote
Fiberglass bondo or regular? Rubberman2003 Body - Exterior 2 08-17-2003 08:12 AM
bondo and fiberglass bruce-77346 Body - Exterior 4 05-06-2003 03:28 PM
Fiberglass or body filler (i.e. MicroLite, Bondo, Evercoat) CustomFord Body - Exterior 1 01-27-2003 10:00 PM
Help with bondo / bodywork please =) manofsteel Hotrodders' Lounge 3 12-04-2002 07:05 AM
does fiberglass with a bondo skim work better than just bondo 72chevyelcamino Body - Exterior 3 10-22-2002 02:45 AM
