Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bondo over primer?
Old 06-11-2002, 07:42 AM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
Post
Your lacquer primer is OK. You do not want to apply the bondo over the primer, Sand or grind down to metal or other bondo before applying bondo as it has to have something to stick to besides primer. Sand out a larger area than what you will be working.
