bondo removal question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2003, 02:23 PM
Red face bondo removal question
was wondering if anyone had any tips for bondo removal in body panel cracks
i got my bronco from a guy who filled in all the body panel cracks with bondo and of course that being a flex joint the bondo has cracked was wondering if there is a chemical i can use to get the bondo out of the crack are a trick of some kind thanks for any input
broncoman
Old 06-21-2003, 05:21 PM
New Member
the best way to get bondo out is sanblast the panel
Old 06-21-2003, 08:36 PM
BOBCRMAN@aol.com's Avatar
If you are careful you can heat the panel and the filler will fall off, but you have to be CAREFUL!
Old 06-22-2003, 01:16 AM
paint stripper eats filler too... you still have to get it out, but a wire brush will do it...
