I just scrape the edge of mine off with another spreader. On that spreader it balls up in the middle then just wipe it off. Then I spray it with wax and grease and wipe it down competely.
Wow Guys. Thanks for keeping me entertained at 3 in the morning. Just couldn't sleep. Too much caffeine at cruise night I guess.
I love your idea Brian. Can't wait to try it. When I am working I keep about 6 spreaders in a coffee can with about 3 inches of urethane reducer in it. Be sure and keep lid on and the filler won't harden. Each time I need a spreader I get the bottom one, wipe it off with a shop rag and go. The next time though I will be adding the cardboard box trick. Sounds like a neat idea. Josh, I am hoping and praying you meant to say wax and grease remover LOL big time.
Good trick Brian.
Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
MIKEY!!!! WTH! MIKEY, HOW THE HELL ARE YOU DOING! OMG it's MIKEY!!!!!!!! Of course with a brilliant mind like yours you see it as it is, "Heat" you are effectively melting the edge making it smooth, I never looked at it that way! MIKEY!!!!! I can't believe it how are you? Brian |
Durn netnanny blocked the video. I'll have to watch it on the wife's computer tonight seeins how my handme down from her has no sound...the reason she got a new laptop last year.
I always appreciate Brian's contributions. |
I just use a scuff pad with thinner to clean it off then wipe it on my pants to clean up the edge.- lol.. Well until they stop getting our work clothes washed for us.
Great tip Brian! Im going to try that!
I'd like to add the suggestion of using Honey to thin the filler for a skim coat. This is something I never knew about till recently! And what a difference it makes! The filler drys so smooth it's almost shiny! Now this isn't Honey from bees. Evercoat makes it. It actually looks like honey. It really is nice for spreading larger area thin skim coats.
It blew me away when one of my mentors showed me that, changed my whole world in the body shop I'll tell you that. If you like that "Bondo honey" you need to give Glaze coat or Metal Coat a try. You can spread it over the filler for s skim coat of course, but you can also mix it in with the filler like "Rage" and thin it.
It sands much easier than the filler with "Honey" (fiberglass resin) in it. Brian |
When the polyester putties like "Metal coat" (the first "pourable" putty made) came out, thinning filler with resin was a memory for me.
http://www.evercoat.com/productdetail.aspx?pid=1 "Glaze coat" is the same product but a different color. The hardener is white, very hard for some guys to mix properly so I don't usually mention it. But it is the same great polyester putty. http://www.evercoat.com/productDetail.aspx?pID=2 Personally, if Evercoat made televisions or underwear I'd by them, everything I have ever tried of theres is top notch. Brian |
I am looking forward to trying that myself. I have thinned Rage with resin which does make spreading smoother but it also makes blocking more difficult, IMO. Mixing with a good smooth glaze should work perfectly.
John L |
| yellow colored stain under "bondo" | Hwyhogg | Body - Exterior | 5 | 04-05-2010 07:41 PM |
| Tip of the day 12-11-08 Prepping "Bondo" tools. | MARTINSR | Body - Exterior | 14 | 12-12-2008 09:42 PM |
| Trying to bondo an "Oil-canning" panel | 2stroketurbo | Body - Exterior | 19 | 12-08-2006 12:13 AM |
| i need somthing heat resistant to "bondo" over a weld on a pipe | lowROLLERchevy | Body - Exterior | 8 | 08-02-2005 05:11 AM |
| groovy new (to me) all-metal "bondo" experiment: warning:long read | bullheimer | Body - Exterior | 5 | 10-10-2002 12:33 PM |
