Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - boneyard rear dif for s-10
Old 02-04-2013, 02:48 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
All of the GM trucks with the limited slip G80 differential got the Governor Lock differential. This thing is so weak that they are only good for a stock truck with stock tires, and then they still break. Usually the gear on the governor is all that breaks, which makes it work like a standard differential. Upgrading to the Eaton Posi is the way to go for a high performance GM truck.
