Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - boneyard rear dif for s-10
Old 02-05-2013, 11:37 AM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
Put in a new Eaton Posi and new bearings. If you have a '89 or older rear end then it will have 26 spline axles. You can upgrade it to 28 spline axles, which is what I recommend. If you have a '90 or later then it should already have the 28 spline axles. This is assuming that you have the 7.5 rear end.
