boneyard rear dif for s-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2013, 09:52 AM
im looking for a rear end with a 3.08 to 1 ratio or maybe even less, rear differential for an s-10. does anybody know of vehicles with any narrow rear differential that had that gear that i should be scouring the bone yard for? it has to hold up to mild sbc build.
Old 02-04-2013, 10:06 AM
gearheadslife's Avatar
MentalMuffinMan
why not the one under the truck
Old 02-04-2013, 10:23 AM
big gear head's Avatar
High Performance Rear Ends
If this is a 2 wheel drive S10 and you need something stronger than the 7.5 rear end then your only choice is a rear end from a 2 wheel drive with the 4.3 and a 5 speed. Some of them got the 8.5 rear end, but they are kind of rare. There is no other production rear end that is as narrow as this, so looking for something else would be a waste of time.
Old 02-04-2013, 10:52 AM
MentalMuffinMan
sorry,, the ford ranger 8.8 is almost a bolt in for the s-10..
maybe no gm alxe that narrow
Old 02-04-2013, 10:53 AM
Frank with an S-10 rear end.
I think I have one for $200 that did come out of an S-10. You would have to rebuild the brakes.I believe I have a second one that I was going to put under a '32 Chev I have, but the S=10 is actually too narrow for the '32 and I have another 10 bolt that is just right for the'32.One S-10 has the spring pads cut off. your choice. frankdelrees@aol.com.
Old 02-04-2013, 11:07 AM
Doesn't the Ranger rear end have a lot of pinion offset? The S10 rear end only has 1/2 inch offset. I know a lot of S10 guys use the Explorer rear end and they cut the long side down to the same length as the short side and use 2 of the short axles to make it work.
Old 02-04-2013, 11:36 AM
MentalMuffinMan
not the 2wd rangers
Old 02-04-2013, 11:40 AM
I wonder why those guys go to all of the trouble to modify the Explorer rear ends when the Ranger rear end would be so much easier. I know that the Ranger has some pinion offset because they have a long and a short axle too. The Ranger short axle is the same length as the FOX mustang axles.
Old 02-04-2013, 12:20 PM
MentalMuffinMan
well up here finding a 2wd one is hard..
I know we didn't cut the housing, can't remember how off center the pinion was.. it's been a good 8 years ago
Old 02-04-2013, 12:45 PM
the existing rearend has the wrong ratio and pretty much never does bolth tires spin unless you get it sideways and loose. other than that its a candidate for rebuild.
Old 02-04-2013, 01:48 PM
All of the GM trucks with the limited slip G80 differential got the Governor Lock differential. This thing is so weak that they are only good for a stock truck with stock tires, and then they still break. Usually the gear on the governor is all that breaks, which makes it work like a standard differential. Upgrading to the Eaton Posi is the way to go for a high performance GM truck.
Old 02-05-2013, 09:38 AM
thank you for the heads up. so it would be wise to build up the rear dif that i have now properly? i am not opposed to that.
Old 02-05-2013, 11:37 AM
Put in a new Eaton Posi and new bearings. If you have a '89 or older rear end then it will have 26 spline axles. You can upgrade it to 28 spline axles, which is what I recommend. If you have a '90 or later then it should already have the 28 spline axles. This is assuming that you have the 7.5 rear end.
Old 02-05-2013, 11:48 AM
The Rangers & Mustangs got the 28 spline 8.8 rear. The Explorers are 31 splines and many have factory disc brakes.
Old 02-07-2013, 07:11 AM
thank you for the replys. Would a reaf diff from a 4X4 99 blazer work well? I have one. my dad has a 2002 s-10 and it has had many rear dif problems and a bunch of the bearings and seals which constantly go bad, are mitsubishi parts. i want to stay away from that.
What cars shold I be looking at in the boneyard to souce the rims? hduff Suspension - Brakes - Steering 0 11-19-2012 05:34 PM
boneyard 454 boatanchors Engine 6 12-19-2008 02:18 PM
boneyard pics & I WANT THEM ALLLLL!!!!!!!! TooMany2count Hotrodders' Lounge 23 09-03-2003 10:29 PM
boneyard seats topdek Interior 5 01-11-2003 11:08 AM
Old Car Boneyard 6 Pages roys63 Hotrodders' Lounge 17 10-16-2002 02:09 PM
