Those pontiac tails are notorious for bad grounds because of how the inner pan and the outer bezel are pinched on the rear of the car with gaskets. I had to run a separate ground wire to a screw from the light pans in my 66 Bonny. Check continuity from the light pans to the frame or other good ground and see what you get.
GM 60s cars are plagued with bad grounds on rear lights.
Even if you get a good reading with an ohm meter while checking the ground to each rear light housing, that ground could "go away" if you put a load on it with one bulb trying to light up. My 64 chevelle drove me nuts back in 1968
Thanks for the suggestions, it appears to be my turn signal switch. If I jiggle the handle, the light comes on. I will delve into this further and post what I find. Thanks again.
Mike |
| Turn signal switch problem? | junkyardjeff | Electrical | 1 | 05-04-2007 12:59 AM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| brake light, turn signal, tail lamp problem | worknprogress72 | Electrical | 6 | 01-06-2006 12:20 AM |
| How many rodders does it take to change a light bulb? | Dusty82 | Hotrodders' Lounge | 6 | 09-01-2005 10:02 PM |
| turn signal and brake light problem | PrimeMover | Electrical | 5 | 05-27-2003 06:26 PM |
