Which book should I read to learn SBC?
Searching through Amazon.com I find endless of books dedicated on Chevy Small Block Performance.
I have no previous experience in engines and I would like to learn how to make a SBC put out around 400-500 hp. Which book should I go for? If you have read the book yourself please give a little comment about it. What was good/bad, was it suitable for a newbie, etc? Thx in advance. EDIT: Maybe i should add that I will use a carb, therefore injection-specialized books will not help. Last edited by Gilligan; 09-28-2004 at 10:21 AM. |
SBC Books
IMO, by far the best book for learning about the high performance side of the SBC is Small-Block Chevy Performance by Dave Emanuel.
For rebuilding, the tried and true How to Rebuild Your Small-Block Chevy by David Vizard is a good book. I do not have John Lingenfelter's book: Modifying Small-Block Chevy Engines: High Performance Engine Building and Tuning for Street and Racing, but I am sure it would be a good book. I guess the same could be said for David Vizard's book How to Build Max Performance Chevy Small Blocks on a Budget (S-a Design). But based on the good content in his rebuilding book, I'll bet this is good source as well. Save your money and do NOT buy HP Books' How to Hot Rod Small-Block Chevys. I think the last issue was around 1976. It still has some good information, but it is quite a bit outdated. Looking at the Amazon links above, it appears that there are some pretty good package deals with the books I have listed. Happy reading Ed www.edgesz28.com__________________________________________________ Who is Jesus?.
David Vizards "Max Perf. Samll Blocks on a Budget" is pretty good. Just keep in mind it is a budget minded book, so no high dollar heads or superchargers or cranks or anything like that is covered. The heads he covers are stockers and a few cheaper aftermarket, same with cranks and rods. Nitrous Oxide is covered pretty well too. I've had mine for a few years and every time I re-read it I seem to find another helpful hint.
BTW, I'm sure the Lingenfelter book is good as well. |
Could you say the the combo "Small-Block Chevy Performance" and "How to rebuild you Small-Block Chevy" is good for the beginner? U use the second book to learn about engine basics and the first to learn about performance tuning. How advanced is the first book you mentioned? What's good and what's bad with it? Last edited by Gilligan; 09-28-2004 at 10:28 AM. |
Re: SBC Books
[QUOTE]Originally posted by edge
Save your money and do NOT buy HP Books' How to Hot Rod Small-Block Chevys. I think the last issue was around 1976. It still has some good information, but it is quite a bit outdated. I forgot I had that book. I can't believe I didn't check the date on that book when I bought it at PAW a couple years back. 30 year old vintage information.
I said budget oriented, not weak. 400 horsepower is not beyond whats in this book. BTW, he's got a 575 horsepower naturally aspired 383 stroker example, using sportsman II heads, stock 400 crank, etc. |
