Boost 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2004, 01:12 PM
New Member
Boost 700R4
Hey,
I have a 1981 Chevyvan with a stock 350ci small block with a single turbosystem and a TH350 transmission. I adjusted the vacuum modulator of the TH350 so it will shift firm when the turbo make boost, even when the kick down cable is pulled half way. I can drive with boost even when I give half throttle. But when I replace the TH350 with a 700R4 I only have the TV cable that controls line pressure. So when I drive half throttle with the 700R4 and the turbo give boost, the line pressure may be to low to shift the transmission firm and I can burn clutches. Does anyone have a solution for this problem? Is there a component that rise line pressure when the turbo give boost?
Thanks
Old 01-12-2004, 03:15 PM
classic_chevy_guy's Avatar
70Chevelle/91Eclipse
Last journal entry: My 81 Silverado(SourApple)
if you look in summitracing magazine, jegs, or go to one of their websites they actually have kits that can help you out,and i think they have something for the kickdown, i know they have some tubes for pretty cheap, but i was looking at them just in case i had the same problem. hope this helps.
classic
Old 01-12-2004, 03:51 PM
willys36@aol.com's Avatar
Wiki Edits: 21
This kit allows tuning the hardness of the shift while maintaing the proper geometry throughout the trave of the throttle.
http://www.tvmadeez.com/index2.html
