boost adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2010, 04:57 AM
boost adjustment
how do i make a boost adjustment on a turbo charger? either to raise or lower boost pressure
Old 01-19-2010, 05:59 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Depends on the design on the turbo. If the wastegate is adjustable there will be a set screw with a jam nut. You will loosen the nut turn the screw in small increments and then tighen the jam nut back down.
Other turbos that come with a certain lb spring like say 8lbs you can use a boost controller. They have mechanical and electronic ones. The mechanical ones are a lot cheaper but aren't as sophisticated. All the boost controller does is plug in between a boost/vacuum reference port on the intake and the waste gate. It will fool the waste gate in thinking that the turbo isn't building as much boost as it really is causing it to keep spooling.
I had a friend that had a 6.5L diesel and modified his wastegate with an 18lb spring. Very neat design.
Old 01-19-2010, 06:02 AM
sqzbox's Avatar
My pipes are my music
Check out this site. Has a lot of info. One thing about the boost controller, you can turn it up or down depending how froggy you feel.
www.boostcontroller.com is one site. You can google "turbo boost controls" and get all kinds of info. and products. Then it's up to you for feedback from this site on what works best.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Cheap boost idea. What do you think? V8 Super Beetle Engine 45 05-07-2009 03:47 PM
Supercharger boost Question. rising68 Engine 1 12-31-2008 07:49 PM
Adjusting olds rockers .... HELP A/G WILLYS Engine 7 08-21-2008 12:22 PM
Turbo or Super? (Forced Induction Systems: Pro and Contra) Nightrider Hotrodding Basics 4 02-14-2005 10:50 AM
