Originally Posted by 427blownvette
Since winter is now hitting us here in PA, I have alot of time on my hands. I have read the many posts on this site about boost referencing power valves and even though my car seems to run fine without the carb being referenced and my low boost (5lbs) I am going to reference my carb.
I have already locked out my vacuum advance distributor. I have my mechaincal timing at 28* as per some advice from members on this site. 18* initial and 12*mechanical.
My blower intake only has 1 port available to connect to under the blower. Is it ok to have my vacuum advance distributor, boost/vacuum gauge and for the boost referenced power valve on the same port?
You can tee off or drill & tap the manifold for another or as many vacuum taps as you want. Whatever end method you use, make sure the vacuum lines are held onto the tube, tee, whatever positively so they do not come off under boost.
If you have a automatic transmission that uses manifold vacuum for a modulator, THM 350, THM 400, Etc., it is a good idea to install a spring loaded check valve so boost won't enter your modulator.
Even with just 5 PSI of boost you still need to reference your carbs to the manifold below the blower.
