Boost/Vacuum gauge W/ Edelbrock RPM Air Gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2007, 10:03 PM
Last journal entry: epoxy paint
Does anybody know If an RPM air Gap manifold has a place to screw in a mechanical boost/vacuum gauge. Its the mechanical part, the clear tube with a 1/8 threaded Fitting. It also has a larger adapter. After looking at my manifold I think it will be the adapter that will fit.
Does anybody have a SUNPRO mechanical vacuum gauge like this. Im wondering where on the manifold it is supposed to go. There seems to be a few places I might be able to screw it in. Thanks
Old 07-11-2007, 07:18 AM
Most of the Edelbrock manifolds for Chevy's have a threaded vacuum port on the passenger side of the manifold, just behind and to the side of the carburetor. This is where you connect the vacuum for your HVAC and the vacuum line for an automatic transmission (TH350, etc,). You can use rubber hose and a vacuum T to connect a vacuum gauge there.
There is also usually both a manifold vacuum and a ported vacuum connection on the front of the carburetor, and you can T into the manifold vacuum line.
Bruce
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
RPM Performer or Air Gap ??? Guy Hiltz Engine 17 12-01-2006 05:03 PM
Edelbrock RPM Air Crossover Coolant Hoses DTL504 Engine 4 02-20-2006 02:33 PM
Air Gap or RPM or Stealth? Jacks77 Engine 7 08-27-2005 10:08 AM
