booster? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2013, 05:15 AM
booster?
Hi guys im building a 86 iroc camaro. I installed a aftermarket brake booster and I would like a aftermarket master cylinder but because of clearance issues the lines need to exist out off the passenger side so far I haven't found any from Jegs or summit ect. The car has willwood disc brakes all the way around and should be in the 9sec range in the 1/4 if that matters.so if anyone could make any suggestions it would be great thanks alot
Old 07-12-2013, 08:04 AM
You might want to look at those vendors again. Everyone sells a version of the GM master cylinder with outlets on both sides. You just plug the ones you're not using.
Speedway Motors has it in iron ($60) and aluminum ($100):
Old 07-15-2013, 01:28 AM
Thanks for the help I will recheck and go from there
brake booster mafiacustomz Suspension - Brakes - Steering 3 07-23-2011 08:56 PM
Octane Booster smokin63 Engine 10 03-27-2008 05:56 PM
octane booster??? elcaminodragster Hotrodding Basics 2 03-14-2007 09:37 AM
MC Que. with booster 39chevy Suspension - Brakes - Steering 1 12-31-2006 01:04 PM
which booster cornfieldcars Suspension - Brakes - Steering 9 08-07-2005 02:51 PM
