Boosting CR with head gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2011, 10:58 AM
I'm going to build a .060 over 350. I should hopefully have a set of federal-mogul .060 over flat tops coming real soon. I would like to get at least 9:1 out of this engine, BUT all I have right now is a set of those crappy 462624 76cc sbc heads. The pistons are rated at about 9.35:1 with 64cc. I know it's not alot at all, but if I used a thinner head gasket with the 76cc heads, how much do you think I could get out of it? Anyone have a gasket recommendation?
I plan to use the lunati 60103 cam. I have had awesome results with voodoo cams in the past, but I know this cam is going to need a little more than my usual 8:1. Please note, I am still in the market for a good set of 64cc heads, but my budget is a little tight on this one and using the 76cc heads is definatly not set in stone, but a possibility. Also I'm getting the pistons on a trade (they are brand spankin new and they are free), or else I would go with a domed piston. You guys give out some good info, even saved me from blowing money on something that wasn't going to work. Thanks for your opinions and bearing with my noob questions!
Old 03-28-2011, 11:16 AM
327NUT's Avatar
If it was me and this wasn't my daily driver I would just wait and keep looking for the 64 cc heads, there's a lot of them out there. You won't pick up the needed compression with a head gasket change. Sell the 76's and start saving your money cuzz a "Band aided" engine is not the way to go just to get it on the street, you'll waste your time and money.
Old 03-28-2011, 11:47 AM
I agree with you. I guess I'm just in a hurry for summer. My Mom has never ridden in this car and I really want to take her for a ride, plus I haven't seen her in a long time (long story). That being said, I have been looking at the patriot performance heads. I can get a set of 2.02/1.94 64cc aluminum heads for about $800, and I guess if I'm gonna spend money I might as well make it count.
Old 03-28-2011, 11:51 AM
Originally Posted by F-BIRD'88
The low buck fix:
Find a set of #4416 305HO heads and home port them with 1.94" x 1.60" valves. fully Port to a felpro #1205 gasket.
They will be 60-63cc when you are done the rework/deshrouding on the chamber for the new larger valves.
Measure the pin height of the pistons ( 1.56" stock 1.54" (rebuilder type) reduced compression height= crappy quench and low cr)
Install the heads with a felpro #1094 gasket.
This cam will not work with low compression or restrictive heads (624-882)
I figured this cam would be a little needy. I hate to say I'm building an engine around a cam, but this profile just fits perfectly for what I'm looking for. I'll save the $$ to make it perfect, that voodoo line is a really good line of cams
Old 03-28-2011, 01:35 PM
You're far better off to use a small chamber head with D dish piston and tight squish of about .04 to .06 inch. Big chamber heads have poor combustion, and domes make it worse. You can get power but it comes at the expense of a lot of 4 dollar gasoline.
As a short term fix you could run a .016 thick Fel Pro gasket which would deliver 9 to one if the block isn't decked, 9.5 if it is at zero.
I wouldn't start out to build an engine this way, but for free parts, there's plenty that can be done with a little added milling of the block deck and/or heads to make this work pretty good.
I didn't run a dynamic cr on this as it takes time to look up all the cam specs and run the calculator that I just don't have at this moment but go here with the data and get some results you want somewhere around 8 to 8.5 to 1. http://www.kb-silvolite.com/calc.php?action=comp2
Bogie
Old 03-28-2011, 06:45 PM
I'll sell you my felpro 1094's .015 compresses 25 plus shipping I can't use them because I am .018 in the hole and quench will be to tight
Old 03-28-2011, 08:06 PM
327NUT's Avatar
HaHaHaHa....well I''VE got some used felpro's that are already squisshed, more gooder for gooder compression............SJK, have you ever read the guidelines reg: no selling or buying on the forum???
Old 03-29-2011, 04:04 AM
Some other Junkyard jewel hi compression heads you can watch for are the TPI heads from 305 or 350 camaro firebirds with TPI injection. "081" (305) "083" (350 L98)
Didn't the 083 (iron) heads come with a 64cc chamber on the F-body? The good 350 HO heads only came on the vette L98 iirc.
The 305 heads (081) should have 58cc though, yep.
Old 03-29-2011, 05:03 AM
Sorry I actually never read the regs. I'm used to the MC racing forums, where posting sale items is not allowedbut in conversation its no sweat. SOrry I will do 200 keyboard strokes for making a mistake.
Head Gaskets J.D Engine 5 07-15-2008 07:43 PM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
head gaskets!!!! thefloyd1973 Engine 1 04-24-2007 02:06 PM
Head Gaskets Canadian Charlie Engine 3 07-23-2005 02:16 PM
MLS Head Gaskets TurboS10 Engine 9 07-04-2005 06:51 AM
