bop th400 torque converter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2006, 07:31 PM
The trans is a bop th400 and im using an adapter plate to hook it to a small block chevy. I ordered a B&M 3000 stall converter from jegs the other day that said it'll fit any GM 1965-91 TH-400/425/375. Since it says GM i assumed it meant both BOP and Chevy cases. The converter thats in the bop trans is about 12 inches and the B&M 3000 stall is maybe 10 or 8, im not sure, but there is a significant difference there. I sold my chevy th350 but i thought it had about an 8/10 inch torque converter in it...or pretty close to the B&M one. Since the chevy case is smaller im sure thats the reason the converter is so much bigger in my bop but is it ok to run that smaller converter? Any help is greatly appreciated.
Old 04-24-2006, 05:49 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Higher stall speed converters are generally smaller than lower stall speed stockers.
Old 04-24-2006, 10:25 AM
ok thanks alot, haha can never be to safe.
torque converter to flexplate bolts?? gavinpierce Hotrodding Basics 4 04-20-2006 04:25 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 11:08 AM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
