bopc 2004r to chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 07:48 PM
Last journal entry: Future Plans
bopc 2004r to chevy
Well my th350 is packing it in so i want to go to a 4 speed auto and i want a 200r4, well i was wondering if there are adapters to mate a 2004r from a BOPC to fit a chevy?
thanks
Old 11-20-2005, 07:58 PM
BOBCRMAN@aol.com's Avatar
2004R already has a universal pattern.
Old 11-20-2005, 08:23 PM
BOPC and chevrolet both had there own 2004r's but there were some universal 2004r's like the one on the bottom of this page
universal
Old 11-20-2005, 10:08 PM
That is the turbo 200. Not an overdrive trans. All the 200R4's are universal.
Old 11-20-2005, 10:56 PM
well if you close under the image it says its a 2004r
Old 11-21-2005, 06:11 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Actually it says.....
"The TH200-4R is identified by 10 bolt holes and 2 dowel-pin locator holes on the universal bellhousing. It has a dual bolt pattern for both Chevrolet and BOP (Buick, Olds, Pontiac) applications. The TH200 has only six bolt holes and 2 dowel-pin holes."
Old 11-21-2005, 07:49 AM
tnsmith10's Avatar
when will it rain???
that was a 2004r... just with a snapped input shaft... they bolt right up and the only thing ull have to change is the cable... the th350 uses a detent cable, and the 2004r/700r4 both use a throttle valve cable. make sure u set it right or failure can occour... gl
p.s. u will also have to buy a kit for tcc control, otherwise ull burn up o.d. a toggle will work, but its too easy to forget about it...
Old 11-21-2005, 08:03 PM
so then are all 2004r's interchangeable to fit a chevy?
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 11:32 PM
Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? mistermuscles Transmission - Rearend 0 07-18-2004 06:40 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 04:04 AM
