bore - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2012, 12:27 PM
bore
What does it cost to get a 400 small block bored
Old 02-27-2012, 12:44 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Call machine shops in your area and ask them.
Old 02-27-2012, 01:19 PM
In my area ( South Carolina ) the GOOD shops charge 8 dollars a hole. It is a additional 30 dollars to bore it with head plates installed.
DEUCE ... Moderator
Old 02-27-2012, 03:53 PM
BOBCRMAN@aol.com's Avatar
Wow! eght dollars a hole? I can't remember it ever being that cheap in Michigan.
In this world. It's over $175.00 up to .040" over. Block plate hone is another $50-75.00 extra. Then there is cleaning/mag inspection. Soft plug and cam bearing r&r. I'm a mid priced shop..
Spread Bore VS Square Bore Advise daveh Engine 22 01-05-2012 07:35 PM
Edelbrock square bore to spread bore GUITAR1989 Engine 15 08-01-2011 07:04 AM
Square bore VS. Spread bore JimKramer Engine 6 08-06-2010 09:57 PM
spread bore to square bore adaptor? david ahluwalia Engine 11 03-21-2009 07:15 AM
Spread bore with square bore carb western star Engine 5 10-28-2004 02:16 PM
